Can you upgrade wifi card in airport extreme 2gen?
hey everybody
is it possible to upgrade the wifi card to something faster?
Your AirPort is currently an 802.11n compliant unit.
Have you checked and if needed updated the firmware? Apple did make some speed improvements within the Extreme's firmware.
Otherwise you will need to review your network's design to see if one of the interconnections are running slow. Where are you encountering slowness, Local or the Internet via your ISP?
这个答案有帮助吗?
I think by faster he means something 802.11ac or similar. I came here with the same question.
这个答案有帮助吗?
Sadly, the physical interface the AirPort card uses in this unit is not able to support anything newer. Time for a new WiFi Router.
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 457
2条评论
Can you give us the model number of your unit so we can see what you currently have.
由 Dan 完成的
sorry for not writing it, its a A1143 if its that you mean
由 andreas 完成的
