跳转到主内容
加入维修社区 - 创建账户
The Canon AE-1 is a 35 mm single-lens reflex (SLR) film camera for use with interchangeable lenses.
Why is the shutter magnet stuck?
After a trip to the sand dunes, I guess sand got into the camera because my camera started taking pictures as I pulled the film advance lever (and apparently this happens if dust or particles, like sand, interferes with the magnet.)
So... I decided to clean the magnet and fool around with the mechanics at the bottom of the camera. I eventually got the magnet to stick to the coils on its own.
BUT NOW... The problem is that the magnet can't detach from the coils on its own. I have to manually move the magnet if I want a picture taken. Does anyone know how to unstick the magnet without having to replace the magnet?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I have a Canon AE-1 program. It was left in a hot area. It messed up something on the inside of the camera. Is there anyway to have this type of camera repaired, or is it just not worth it?
完成的
添加一条评论
5个答案
最有帮助的答案
The magnet is an electromagnet so when current is applied it de-magnetizes for a split second to release the bar when then causes the shutter to function.
If the magnet is not releasing then the fire wires of the windings have become damaged as power is in unable to pass though it. Check to see if you damaged or dislodged something when you cleaned. If you don't see anything its time to break it into a camera repair person as you do need some specialized tools to test and repair the control circuitry as well as gain access to the needed parts.
这个答案有帮助吗?
得分 1
添加一条评论
hello great advise and what does the magnet look like after you take the cover off?
thanks
alreddy@yahoo.com
这个答案有帮助吗?
得分 0
1条评论:
Here's an image with the bottom removed: Bottom cover removed. Do you see the two copper coils at the bottom under the plastic cover thats the release electromagnet.
完成的
添加一条评论
Hello good afternoon!
I was reading the mentioned problem and if you enjoy with my ... so in my case the electro magnet does not stick to be able to engage the movie ... is it dirt that is preventing ??? Any help is welcome, grateful (Celso do Brasil)
Ola, boa tarde!
Estava lendo o problema mencionado e se aprece com o meu... so que no meu caso o eletro imã não gruda para poder engatilhar o filme... será que é sujeira que esta impedindo??? Qualquer ajuda é bem vinda, grato (Celso do Brasil)
这个答案有帮助吗?
得分 0
添加一条评论
Very late possible answer
The magnet at the base of the camera is the release magnet. When you wind the camera the release magnet closes, when you press shutter release the magnet releases allow shutter to time out. Check Battery if camera does not release. 6volt PX-28 silver oxide was the original battery when AE-1 was introduced. Alkaline equivalent is ok but will not last as long. Sand and water are not friends of electronic cameras.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem, shutter firing as soon as I advanced the film.
I cleaned the magnet and coil ends that contact the magnet with isopropyl alcohol on a q tip
Then the magnet would stick but not release no matter what I done. I was stumped for a few days checking components and reading online but couldn't get an answer
Ultimately it was a very simple solution. Spray wd40 or light oil on a q tip and rub the areas that were cleaned with isopropyl alcohol. Worked immediately.
If it doesn't work for anybody reading this, check that the coil measures 90 ohms approx of resistance with a multimeter. If there's no resistance then you have an open coil which means find the break or replace the magnet/coil
It's a great little camera and I'm delighted to have mine working again
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adsfjdskj aksdjfkldjf 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 80
总计 12,402
