跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 个问题 查看全部
Can not install OS X Jaguar nor Panther on my IBook G3 900 MHz 12"
My IBook was running fine with OS X 10.3.9, after attemting to install Tiger 10.4.x on it, the install program self aborted with a message of "errors detected".
Now seems that my HD 40 GB is "corrupted" and I am not capable of re-instaling even the 10.2.x OS X. I have tried to repair the disk with the DISK UTILITY which is enclosed in the original install disk but has nor possible to repair, erase or anything else.
I even tried with DBAN CD, but the program does not show any progress after hours running.
What can I do?
Thanks for your help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Well, you've definitely tried most of my suggestions already.
You could try using firewire 400 to connect it to another mac, from that mac you could try erasing the hard drive with disc utility and then re-imaging it with either the image from that mac or the image from your discs.
这个答案有帮助吗?
得分 2
添加一条评论
Looks like your HDD has non-reprable damage, it needs then to be replaced. Check this guide for instructions:
iBook G3 12" Hard Drive Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rferrer 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 25
总计 2,008
