跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
问题已关闭
Dropped, now screen lights up very dimly when home button is pressed
My daughter dropped her iPad2 from about waist high onto a carpeted floor, landing on its corner. The screen will illuminate very slightly (looks sort of blue) when the button is pressed, but no icons appear. It still functions, she can play music with it, it dings when she receives a text message or e-mail (and the screen will illuminate slightly then, too) but it is obviously not usable. I suspect that the shock knocked a (ribbon?) connection loose.
Could I get some troubleshooting questions fed to me of things I could try? I've already looked at a few questions on here and checked with a flashlight to see if anything is visible, thinking maybe the backlight just wasn't functioning. That's not the case. What else can I try? I don't have an electronics background, but I could probably handle taking the screen off and looking inside if I had a little bit of guidance. Thanks for any help anyone can provide.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Definitely take the glass off. Follow this guide. Make sure that the LCD cable is seated on the logic board and on the LCD. Only don't replace the LCD, just check all the connections.
iPad 2 Wi-Fi EMC 2560 LCD Replacement
这个答案有帮助吗?
得分 1
3条评论:
Thanks David! I'll see her this weekend and after that I can get to work on it. I'll post again with my status.
完成的
The Good News: So I removed the glass ans re-seated the connector for the display and that fixed the problem! The Bad News: while i was removing the digitizer I cut into the ribbon connector, so I had to replace that. I found one on Amazon and successfully replaced it. The down side of that story is the left edge didn't work. So i ordered another, more expensive and seemingly better one. That one has also been replaced and it's working like a dream! Thanks David for your assistance!
完成的
Happy that we could help.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 540
