跳转到主内容
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Why won't my phone switch on?
My Samsung Galaxy S II gt-i9100 phone switched off by itself.I had bought it second hand.The previous owner had rooted it.It was running a nightly build Cyanogenmod OS(ICS Android). I put it on charge for more than an hour but didn't switch on even then.Tried different batteries.Didn't work.Tried to start it in recovery mode by pressing volume down+power+home buttons.Nothing happened.It has not taken any impact and never been dropped in water.I can't tell if this is a hardware problem or a software one. cyanogenmod had been prompting me for a long time to update the OS but i didn't.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
For recovery mode: VolUp+Home+Powe.
For download mode:VolDwn+Home+Power.
If you are sure for battery and charger try this:
As I understand you can't start it in Download mode.
To force Download mode you need USB Jig like this:
http://www.ebay.co.uk/itm/Micro-USB-Jig-...
or you can tray to do it yourself.
http://galaxys2root.com/galaxy-s2-hacks/...
After force Download mode you can flash your phone.
Otherwise you need Jtag box, but this is special service equipment.
Another reason for the problem is hardware failure. The most often problem is in the power i.c. (the i.c. must be replaced). And you need special service for this too.
Regards.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
nayan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 3,017
