跳转到主内容
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 个问题 查看全部
问题已关闭
Is the iPad 2 GPS antenna the same as the 3g antenna?
I accidentally ripped the GPS antenna in an iPad 2 CDMA clean off. Trying to find a replacement part, not a lot comes up for GPS antenna (as per the guide), but if I look for the 3G antenna, lots of results come up, and the antennae seem to look identical. Which one can I use?
The iPad no longer connects to a 3G network at all. In fact, once cellular is switched on it says "No Service" immediately, no searching or anything. Should I be concerned about this? It seems very quick to say no service...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Ordered a "3G" antenna from a 3rd party. Worked fine as a replacement.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 144
