跳转到主内容
The Asus X53E is a 15.6-inch Windows laptop released by Asus in 2011.
15 个问题 查看全部
contact failure on the computer connector to electricity network
How can I open the computer to look inside where the problem lies?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Before opening I would check the power adapter. Can you locate a second power adapter to try out? Or access to a second system (Asus X53E) to try your power adapter on?
Is the connectors clean and not damaged (adapter & system)? If they are dirty unplug the adapter then with a cotton swab (Q-Tip) with some Isopropyl alcohol wipe the contacts. Any better?
这个答案有帮助吗?
得分 3
添加一条评论
recurent prob on asus x53s.
it cames from the dc connector soldered on the MB.
have to change it.
the good news is that it's a relatively cheap spare parts.
the bad news is that you have to got some skills to unsolder the part from the MB.
be carefull not to broke the small and thin MB part on which the connector is soldered. it broke easily if you're too rough.
这个答案有帮助吗?
得分 1
1条评论:
you might want to do this using hot air and solder paste. It'll save you some headaches and cash.
完成的
添加一条评论
添加你的答案
Agathe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 2,151
