Non Responsive iPhone 4s - possessed
Touch screen is non responsive / but if I continue to hold the icon or word - it will eventually go to the next screen. In other words it would take you over 2 hrs to setup the iphone after a factory restore - that's if it didn't automatically put you in a diff. language by default. It has a mind of it's own!!!
I have the exact same problem after just a screen replacement. The Phone boots up, normally, however i cannot slide the button on the screen to open it - the screen is unresponsive. It is my sons phone, and I cannot sync it from iTunes since it needs a response from the phone, which i cannot do, since it is locked... I cannot change the time and date in the phone in order to get it out of the searching mode ... do I order a new screen now just to check if this the problem ?? please help, best regards Rene
由 rclausen 完成的
If you are positive the screen connectors are seeded correctly then yes the screen is faulty
由 con 完成的
