跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Why does my replacement wifi chip not work?
Hi, tried changing the wifi chip but the wifi is still greyed out.
Is this likely to be related to the two small SMD 10K resistors on the right hand side of the chip which are missing? According to the schematic they have to do with the control lines for I2C
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Where did you buy it from? If you bought a cheap one it may be faulty.
完成的
This is true
the cheaper you buy it from the more faulty it gets. I had to pay 20GBP and its still not working.
完成的
添加一条评论
1个答案
最有帮助的答案
You are right, without these resistors the chip will never work.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 264
