跳转到主内容
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 个问题 查看全部
HTC One: After reassembly no GPS-Signal
I replaced the complete Front (Display, Touch, Frame).
After reassembly I have no GPS-Signal at all.
I Really don't think so but maybe I forgot to connect a cable or something.
Does anybody know where the GPS ist located on the motherboard?
Is there a GPS-antenna and where?
Thank you so much
Thmas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Hi,
May be you have problem with antenna connector. Disassemble it again.
Look here:
HTC One Teardown
In step 16 you can see some golden contacts.
Push them up (carefully, you can broke them).
And check back housing on the places where they make contact. I'm not shure which one is for the GPS. You must have connectors for GSM, WiFi, GPS.
Regards.
这个答案有帮助吗?
得分 1
2条评论:
Thank You for answering my question.
I dissambled it again, including mother- and daughter-Board. I checked all contacts I saw. They looked fine but again I pushed them up. Just for sure.
But still no success, GPS isn't working :-(
Is there a possibility to check the GPS-Hardware?
Thank You very much
Regards
Thomas
完成的
wifi no signal
完成的
添加一条评论
I replaced the cameras and charger port and then the GPS stopped working. I took an emergency trip to help my brother and got lost. Contacted HTC and they said it would be about a two week and $150.00 fix. Found this and fixed GPD in three minutes.
http://forum.xda-developers.com/htc-one-...
这个答案有帮助吗?
得分 1
1条评论:
Great. Noticed same.
完成的
添加一条评论
you may missed to plug back the small antena beside vibrator , i just discovered my mistake, it was left under motherboard xD
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thomas Dott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 7,275
