跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
问题已关闭
Unable to turn it on
Hi,
Perfectly working fine and suddenly stopped working and not starting now. Unable t turn it on. Not even showing any battery charging icon when connected to charger. What could be the problem. When trying to start, shows slightly grey screen for 1 second and switches off. Tried press/hold sleep button but no success. Can any one help please.
Thank you
kind regards
suman
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hold power and home button togeather for 7 seconds then let go of home but keep power held down this should kick start it with the apple logo
这个答案有帮助吗?
得分 4
2条评论:
Glad this worked for you
完成的
I just tried this and it worked perfect...THANK YOU SO MUCH
完成的
添加一条评论
Just to add to the discussion a little bit, I do believe this is caused when you repair the Ipad while it's started. Ensure that the unti is powered down before doing any reperation in the future to avoid any damage. :)
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 263
