跳转到主内容
Keyboard backlight does not work!?
I have a MacBook Pro 15" 2.4 GHz (Penryn). I need to know if I should replace the ambient light sensor or the inverter cable/LED board? My screen brightness works just fine, the caps key on my keyboard lights up when pressed, but the rest of the lights on the keyboard do not light up at all. I have tried multiple times to adjust the brightness both on the keyboard using the F5 & F6 keys and in the system prefs pane, with no success. I have also checked to make sure all cables and wires are connected properly, and they are. So which one of the above 2 should I replace to get my keyboard to light up again?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
2个答案
Have you attempted to reset the SMC?
http://support.apple.com/kb/HT3964?viewl...
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue, and on my keyboard there's backlight keys but no actual backlight, maybe it's the same on yours?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nickole Schmidt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 5,115
