跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Which cable controls touchscreen?
Just replaced digitizer, all went well, booted fine, but touchscreen not responding. Do you know which cable controls touchscreen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
最有帮助的答案
Ribbon #2. It can be kinda hard to get in place just right- make sure you hear it click.
这个答案有帮助吗?
得分 2
添加一条评论
Ribbon cable 2 is the touch screen.
这个答案有帮助吗?
得分 1
添加一条评论
and when i unglued the touch screen glass of touch screen ourselves ? What should I do ? when opened, can see perfectly bonded touchscren cable itself and not make contact with the touchscreen glass .What should I do ?
这个答案有帮助吗?
得分 1
添加一条评论
I hope you purchased the right part, Apple in their infinite wisdom made the connectors slightly different from 3G to 3GS.
It could also be that you bought a faulty part, the failure rate from eBay is quite high because the parts are usually factory seconds,
这个答案有帮助吗?
得分 1
添加一条评论
i don't know which i think it 2
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Don K 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 24
总计 12,370
