跳转到主内容
My computer wont recognize my iPod when I plug it in
when i plug in my iPod to my computer it says usb not recognized and it works perfectly it plays music and every thing the only problem is that my computer won't recognize it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
I have this problem too if tried during an external usb, and connecting it strait to the computer. Neither works. Also every time I try to turn it on it blinks orange three times then nothing! How do I fix this?
完成的
Mine won't even play music tho.
完成的
添加一条评论
4个答案
最有帮助的答案
Regardless of which operating system, try updating iTunes: it worked for me once. If that's not fixed, the next thing I would check is the cable and/or another usb port on your computer. If none of that works, I believe it could be the iPod :(. Good luck!
这个答案有帮助吗?
得分 2
添加一条评论
Hi,
to help you we need more information.Is the USB problem the only issue or do you have more trouble like a.e. you can't play songs... Did you drop the iPod or did it got wet ?
这个答案有帮助吗?
得分 0
添加一条评论
it sounds like a problem with the compters usb port. also it could be a problem with the cord itself, and lastly it could be the port on the iPod shuffle. i would recommend a teardown if you know what your doing. but more information would be nice. :)
这个答案有帮助吗?
得分 0
添加一条评论
Try a reset. The Apple support troubleshooter will walk you through this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eder 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 3,676
