跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
631 个问题 查看全部
How 2 fix an iPad thats screen just went black?
it worked FINE the my Daughter logged into an app for Valentines Day, now the screen is all black and it wont turn off or back on. When you plug in the charger...nothing, hit any buttons...nothing?? What do i do? PLEASE help, single Mom not alot of money, so can't afford to take it in to be fixed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 61
61条评论
My iPad mini was charging and my daughter went to go on It and it would not go on..it I a only a year old and I called the help center and they told me that I was out of warrenty and that's why it happened so how can I turn it on
完成的
after that you have to unlocked the screen by switching on the right upper button that sits beside the screen, then you have to turn off the voice over by double touch on screen for setting option under "General" then "Accessibility"
完成的
So thankful I came across this post! Whew, thought I had to buy a new iPad :-).
完成的
Wow. This just happened to me too! Mine is also just a little over a year old. Holding the home and switch button for 20 seconds worked. THANK YOU!!!
完成的
Thank you!!!! I happened to google "my iPad went dark?" & it brought me here. I have created an account and will come back for answers!!
完成的
显示更多的56条评论
添加一条评论
12个答案
已选择的解决方案
Do a hard restart ..
Hold power button and home button togeather at same time for about 7 seconds then let go off home button and keep pressing power.. It should restart!
这个答案有帮助吗?
得分 102
111条评论:
thank you!!!!!!!!!! Just the answer I was looking for:)
完成的
Thanks for this, it has just helped us as well!
完成的
thank you. om g. it worked! life saver. thank uuuu
完成的
My screen did the same thing but it is not coming on
完成的
it worked…thank you
完成的
显示更多的106条评论
添加一条评论
After that you have to unlocked the screen by switching on the right upper button that sits beside the screen, then you have to turn off the voice over by double touch on screen for setting option under "General" then "Accessibility"
这个答案有帮助吗?
得分 2
1条评论:
We just returned from a trip to Europe and they made my son check his bag at the gate last minute. We were sure it was somehow damaged during transport, but THANKS TO YOU, I was able to fix it. I'm so appreciative of people like yourself who are willing to share the knowledge so many of us don't have a clue on. BLESS YOU !!!
完成的
添加一条评论
Plug it in to recharge it.
It worked for me.
这个答案有帮助吗?
得分 1
2条评论:
Thank you, thank you, thank you, just got for xmas and was ready to burst out in tears! Thanks again!
完成的
Definitely, this was helpful.
My gadget restarted and black screen disappeared!- Kedrick.
完成的
添加一条评论
try pressing home button and Switch button Simultaniously for 20 seconds. Apple logo will come and thats it.
这个答案有帮助吗?
得分 1
添加一条评论
Go to settings then general check lock and unlock switch off if on make sure it is not green.
这个答案有帮助吗?
得分 0
1条评论:
Many thanks - worked perfectly.
完成的
添加一条评论
I was minimizing my screen with my fingers and my screen went black. I could see the icons through the screen but it would not go away. I tried to use your idea of pushing the home screen and the on and off button together for seven seconds and rebooted it but it still came back the same way any other suggestions.
这个答案有帮助吗?
得分 0
1条评论:
Try waiting until battery flat before recharging. Also try switching off for a few minutes.
完成的
添加一条评论
My ipad 2 screen blacks out for about 30 seconds then comes back on. It does this often
这个答案有帮助吗?
得分 0
1条评论:
Rebooted it. It works fine now.
完成的
添加一条评论
I need help.. I don’t know what happened but my ipad mini 2 screen is black when i turn off and turn it back on. I have to restart again and again when this happens. I need a solution,
这个答案有帮助吗?
得分 0
1条评论:
So once you turn it off and on again it’s ok? It happened To me once and I could see in the background underneath all that black where I was able to get to my settings and lighten my screen. I guess what I was seeing was my screen turned down to the lowest amount of light. Then it was fixed.
完成的
添加一条评论
i have same trouble if you turn locks off i dont get black screen any more but after a hour of useing it iturn my ipad off for a hour then back on so it cools down
这个答案有帮助吗?
得分 0
添加一条评论
Charge for 1 hour then turn side switch from off (Red) to on again! Work perfect at no cost.
这个答案有帮助吗?
得分 0
添加一条评论
My Ipad 6th gen decided to went black screen after just pressing the power button, I tried to hard reset it, restore it and put it in dfu mode or recovery mode but it still wont work. This happened to me 9-10 months ago and it went back ok for just a few weeks by leaving it to drain its battery for months and it happened to me again and its been 5 months now, but when I put a flashlight above the screen it will show some display.
这个答案有帮助吗?
得分 0
添加一条评论
My ipad mini 2 screen turns black when I unlock it. I tried so many restarts but its still the same. whenever I lock my ipad, when I want to unlock it, its screen turns black. can someone help me with this?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Melissa Louke 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 33
总计 231,646
