跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
How to unfreeze screen
Screen froze while charging stating that there is not enough storage I cant turn it off and it will not allow me to choose any apps on screen or even slide to unlock or slide to turn off its just stuck please help this phone is my husband and he Is blind and he uses siri for everything,!!!!????????
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
For iPhone user, this method will help you a lot.
How to Unfreeze an iPhone
完成的
wow good job
完成的
添加一条评论
2个答案
已选择的解决方案
Hold down the home button and the power button until the unit shuts down. Then release them both. If the phone doesn't reboot on its own, you may have to press the power button to turn it back on. Make sure that you do not hold the home and power button while the phone restarts because you may accidentally put the unit into DFU mode which would result in losing everything on it - unless you have a program like RecBoot or Tiny Umbrella to kick it out of DFU with!
Good luck!
If you found this to be helpful, please up-vote or Accept Answer.
这个答案有帮助吗?
得分 6
9条评论:
OMG! Thank you so much. It worked. It had been frozen for three long days. I had almost given up. Thank you for your posted answer :)
完成的
Glad to help Debra!
完成的
Thank you! Your a life saver.
完成的
Thank you, that worked!!!
完成的
I really want to say thank you. Your advice worked. Thank you very much. You have been extremely helpful during a hectic time of my life.
完成的
显示更多的4条评论
添加一条评论
i really need your help.. My iphone 4s Freeze and i can't Turn off it because the Notification Center Hang What i will do to fix it?
这个答案有帮助吗?
得分 0
2条评论:
I would unscrew the back and take off the wire connecting to the battery then plugging it back it and try turning your phone back on. I think this video is helpful https://www.youtube.com/watch?v=aSUirUBm...
完成的
Hi @advadvsdv! I feel terrible that I let your comment hang in limbo so long! Did you get this resolved?
完成的
添加一条评论
添加你的答案
joann 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 34
总计 5,430
