跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
How important is the front panel assembly cable bracket
I've had a run in with a screen replacement shop - they repaired a cracked screen in September but the displays functionality has been on the decline now for a month.
It's now unusable (colour lines blur & distort - then cut out) - when I took it back they stated "dust" was the issue - getting a second opinion it transpires they never attached the front panel assembly cable bracket - I understand this acts as a protector if the ribbon becomes detached but could it's lack of presence actually destroy the ribbon?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sounds like a cheap screen.
Not including the bracket is certainly not a professional installation, but no the bracket isn't to blame. It was most likely the cheapest low quality refurb screen available, which often have problems just like this.
这个答案有帮助吗?
得分 3
添加一条评论
Yea mate wonder y they didn't install the baracket? As it says above a cheap screen is probobly the reason.
How long ago was the repair done? They should have Atleast 3 months warrenty
这个答案有帮助吗?
得分 0
2条评论:
Done in September, shop stated they have a 28 day guarantee - lesson learnt I think! Have ordered a screen to fit myself.
完成的
I would be going back to make a fuss anyway and ask them y they left the bracket off
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 776
