跳转到主内容
Apple Time Capsule A1302型修理和拆卸指南。 大多数信息也适用于A1254型。
19 个问题 查看全部
Time capsule hard drive replacement software
If I install a new hard drive in my time capsule, when I power the device up will it boot normally? I recently replaced the hard drive in my MacBook pro and had to jump through several rings of fire to get it working again. I am debating about just buying a new time capsule instead of trying to upgrade the broken disk.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Time Capsules use a different format than a Mac system. So don't bother trying to configure it off of your system.
Once you put in the new disk in, use Apple's AirPort Utility to setup the disk.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Peter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,503
