跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface 系列平板电脑的维修手册和信息。
Dropped my Surface RT and now screen has some sort of greenish static?
My Surface RT was dropped by my little boy, screen didnt break, but once any white page is displayed on screen, the tablet shows like some green static after i start touching screen. With that said, do you think i need a new lcd assembly? Or might it be a loose ribbon cable on the daughterboard or anywhere internally? Screen works fine with dark colors and shows that static with bright colors.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
I suspect the driver chips mounted on the LCD panel has become dislodged. Unless you have some visible damage to the case which could have cut the ribbon cable. I would suspect the display needing replacement. Then it gets into the question on how much will it cost to repair. Did you talk to Microsoft yet? I would.
这个答案有帮助吗?
得分 2
2条评论:
I do not have visible damage! So im guesing its just a chip dislodgement? Would that mean i can go into the surface and lodge it back in? because the screen works fine its just sometimes that it shows thegreen static
由完成的
I have not talked to micosoft yet but sure will the lcd display for the surface runs about 179 on amazon but i think ill have a chat with microsoft support first see if they can give me a hint to fix it! Thank you for your anser dan
由完成的
添加一条评论
添加你的答案
pelon 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 24
总计 2,218
