跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
问题已关闭
White Spots after Repairing Device
So when repairing an iPod touch 4th gen and putting in a digitizer/lcd (got from etech parts) the screen when pushed on a little harder than normal creates white dots or discoloration in the screen. Could it be from a thinner type of glass? I had followed the steps on iFixit to repair it and it comes out with white discoloration each time. So that's why I'm assuming it could be a problem with the quality of the replacement part. Its more noticeable around the edges of the LCD rather than the center.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
The LCD is getting pressure form the shield. You should check the case it could be bent, or the inter shield is bent.
这个答案有帮助吗?
得分 0
1条评论:
I dont have anything putting pressure on it. Its when I put heavier pressure on it than normal pressing and it creates a discoloration in the screen mainly near the top. I have adhesive on top and bottom along with some on the sides with breaks where the LCD goes down into the bezel. I also put a small amount of super glue in each corner for extra hold but still creates that discoloration. I checked to see if any small pieces are on top of metal shield or below LCD and nothing.
完成的
添加一条评论
Have you take off the plastic under the lcd?
这个答案有帮助吗?
得分 0
1条评论:
Yeah I made sure of this! haha I wish it was a simple fix like that!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 138
