跳转到主内容
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 个问题 查看全部
问题已关闭
Non responsive. Dead battery?
I have an iPad 3 that was missing the digitizer and the LCD was trashed when I got it. Tried charging it and connecting to iTunes but it seems non responsive. No sounds and not recognized by iTunes. It has no home button and the dock connector looks ok though the housing is bent around it. No signs of obvious damage to logic board or batteries.
My question is:
Is it possible that the battery is too dead to take a charge? It's likely been sitting in a drawer like this for months.
Is there a way I can test the dock connector to make sure a charge is passing through to the battery?
Also is there a way to test the logic board to make sure it's still alive.
I've only paid $20 for it but want to make sure it's worthwhile buying a new battery, LCD, and front panel for it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
So if the battery is dead and wont take a charge , does that mean the iPad won't power on at all when plugged in?
完成的
添加一条评论
1个答案
If iTunes is unable to read the iPad then you have some major damage to the logic board. Not worth the investment of buying parts.
这个答案有帮助吗?
得分 0
1条评论:
Can Itunes still read it with a dead battery? I metered the battery and it was only measuring 0.7 volts. Which from what I can tell means its shot and cant be recharged.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 666
