跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 个问题 查看全部
How do I set the system serial number after replacing logic board?
I have successfully replaced the logic board and the system is running great. Is there an available tool that works to set the serial number for the logic board? It is currently the default setting, "System Serial#".
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Generally you don't. Only Apple Technicians have access to the software to accomplish this.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 2
添加一条评论
Apple certified service technicians uses Apple netboot diagnostics called AST to serialize a newly replaced logic board. Alternately, they may boot to a blank board serializer software. I'm sure if you take it to the Apple store, they can do this for you since it would be detected that your MLB is blank and needs to be serialized when they run their diagnostics.
Where did you purchase your logic board?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Clark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 2,469
