跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Buzzing on the other side
hi,
I bought the iPhone 4 and I have a problem a buzzing sound on the other side of the conversation.
I removed the last mask, and I have seen that it phone repaired.
The strangest thing is when the finger joints of the left side panel and the lower panel buzzing stops.
as in the picture
http://www.imageupload.co.uk/images/2014...
What do you think which can be?
Thanks for any suggestion
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds like it could be vibration from a broken clip or a missing screw. Perhaps even a loose piece on the frame of the phone. If you follow most of this guide, you should have a chance to see if there are any missing screws, clips or damaged components. If you are not comfortable doing this, be sure to take it to your local repair shop. If you choose to do his yourself, take your time and compare your device closely to the pictures.
Good luck!
If you found this helpful, please up-vote or Accept Answer.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 85
