跳转到主内容
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
42 个问题 查看全部
"No Sim detected" problem
The Sim card detection suddenly stopped. Whatever service is put in, no SIM card detected.
What might be the reason?
What is the Fix?
Thanks,
Ravi
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
添加一条评论
6个答案
最有帮助的答案
I found that my issue was that there is a piece of metal at the bottom of the SIM card slot that when you put it the sim it connects with a sensor that tells the phone a sim is inserted. But the issue is the metal cage does not cover the full sim area and the metal arm can dislodge at the bottom and doesn't connect. I had to take the back off and push the arm back in alignment to have it recognize the sim again.
Hope this helps,
这个答案有帮助吗?
得分 5
添加一条评论
A simple solution/work around to this issue involves placing a small piece of tape or paper behind your phone's SIM card and sliding it into place as normal, don't force it, it should slide in smoothly with no extra force needed. If done correctly, this may make your SIM card fit more snug into the SIM card tray and enhance the SIM card's connection.
这个答案有帮助吗?
得分 2
添加一条评论
I have this Problem after "NO" remedy finaly went to shop who change the Jacket which cost me a good amount
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
I had the same problem and I've found a solution of that problem in youtube. Have a look it might help you as well.
https://www.youtube.com/watch?v=gfNUu4Dj...
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
Geniiioooouuussssss!!!!! Thanks a lot!
这个答案有帮助吗?
得分 0
1条评论:
Which answer helped you?
完成的
添加一条评论
SIM card in my phone but
No SIM card shows me
Please halp mee
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ravi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 24,123
