跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Mini jumping from page to page and opening apps
I updated my iPad mini and now its constantly jumping from page to page and opening apps. What should I do about this problem also, the screen is cracked could that have something to do with it??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
最有帮助的答案
Yes, the cracked screen could be the cause. It could be activating the digitizer (touch sensing component).
Update
Yes, you'll need to replace the digitizer. If the unit is not under warranty, it is possible to do it yourself, or you can have a shop do it.
这个答案有帮助吗?
得分 1
1条评论:
So is there something I can do to fix it???
完成的
添加一条评论
If the digitizer is cracked this could most certainly be causing this jumping. Have you ever had the screen replaced before? Another problem that we find is after a repair if the digitizer is not re-taped properly after a repair.
这个答案有帮助吗?
得分 0
1条评论:
No I heavent had the screen fixed before it was working fine until I did the update yesterday
完成的
添加一条评论
Sounds like the ribbon is bent causing it to jump, this could be from the cracked screen the only thing to do is to get the screen fixed and see if this resolves it.
这个答案有帮助吗?
得分 0
添加一条评论
My mums iPad has these anti smash device called ibalz and these were pressing on the buttons and causing that problem, I took them off and that rectified the problem.
However if you have a cracked screen that too can cause the same problem.
If you can't afford to get it fixed, anything pressing on the cracked area like a protective casing can cause it to go erratic.
Only fixing the screen can fix that problem.
这个答案有帮助吗?
得分 0
添加一条评论
Why does my Sam sung ipad fludder
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keona lambert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,999
