跳转到主内容
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
windows 8.1 with current Itunes software wont recognize iPod
up until today I could plug my ipod on my computer and Itunes would do its thing, today I plug in and Itunes loads but it tells me that it can't recognize my Ipod nano. I have removed and re-installed Itunes and still not luck.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
I can not burn a disc with iTunes and windows 8.1
完成的
Can you please tell me if u can connect an iPod nano 7th generation to a windows computer?
完成的
添加一条评论
11个答案
已选择的解决方案
I was facing the same issue after upgrading to Windows 8.1. You need to remove EVERYTHING that has anything to do with iTunes to fix this problem. Make sure to remove Apple mobile device support, bonjour, Apple software update, Apple application support and of course iTunes. This article will help you to remove everything: http://support.apple.com/kb/ht1923
Now re-install the iTunes software and you’re good to go. I hope it helps.
这个答案有帮助吗?
得分 8
4条评论:
I am experiencing the same issue, but hesitate to totally uninstall Itunes since I have nearly 1000 manually added Album Covers for albums created by converting my vinyl records to mp3's.
Anyone know how to retain that customization?
完成的
I have done this 5 times and its still not working. The apple "genius" people have tried as well and the driver still wont install properly. Any ideas on how to fix this before I go spend a fortune on computer techs?
完成的
Stupid. I have the same problem. Installed itunes for the first time then plugged in the brand new ipod and got the same problem. So, the reinstall software, reboot computer crap is incompetent tshooting. If this does work which I will not try then I am returning the ipod.
完成的
Thank you! It worked for me too.
完成的
添加一条评论
I removed everything as you suggested and re-installed Itunes, it worked!
Thank you for taking the time to answer, you have saved an HP windows computer from being listed on craig's list, under the heading, "computer junk for sale"
Thank you Alex22 for your help.
这个答案有帮助吗?
得分 1
1条评论:
I'm glad I was able to help.
完成的
添加一条评论
Had the same problem, and this fix worked for me too! Thanks!!!
这个答案有帮助吗?
得分 1
添加一条评论
It worked, thanks!
这个答案有帮助吗?
得分 1
添加一条评论
It worked by uninstalling ALL Apple programs and components. Thank you! I had uninstalled and re-installed iTunes several times, without success. However, it worked like a charm after uninstalling Bonjour and all other Apple programs and then re-installing iTunes.
这个答案有帮助吗?
得分 1
添加一条评论
thank you , working good now
这个答案有帮助吗?
得分 1
添加一条评论
It worked for me as well. Win 8.1 with the same troubles of iPod & iPod Nano did not connect to the item, but succeeded to connect to the computer. Fulfill the instruction above worked like a magic. I'm sorry I didn't find this article before spending 3 hours for nothing.
Thanks
这个答案有帮助吗?
得分 1
添加一条评论
THIS is the real solution to the problem at hand. Thank you very much.
这个答案有帮助吗?
得分 1
添加一条评论
Worked a treat!
这个答案有帮助吗?
得分 0
添加一条评论
I was similing before I've done it... In my mind was what a bunch of crazy guys :)))
But I was so wrong. Sorry guys.
Worked perfectly.
Thank youuuu
这个答案有帮助吗?
得分 0
添加一条评论
It works................except! If you have 2 ipod devices then it will recognize one but not the other. You have to go to the control panel and update the ipod device driver and reboot each time you switch ipods.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Javier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 23,632
