跳转到主内容
A high-end smartphone in the HTC One series featuring Beats audio, released in spring 2012.
How to recover data from a water damaged htc one s
have a htc one s recently got water damaged
worked fine for a day after it was dropped in water
suddendly shutted off
dont care about the phone
just wanna recover my data
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
If you cant get the phone turned on the only way is to get a very expensive tool that will actually read the data from a NAND flash chip. This requires precise desoldering techniques and the equipment alone is $1500+
You can send your phone in for water damage repair service to a company like RockIT Repairs and they can run it through a heated chemical process to try and properly clean your phone. Also if some pins have corroded they could resolder them to get the phone turning on again.
Let me know if I can be of further assistance.
这个答案有帮助吗?
得分 0
添加一条评论
water damage should be the battery problem i think, you can set your phone for a few days and try put on another battery see if it can boot.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
moon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 1,937
