跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Is the rear camera the same as the Ipad mini?
Hey im trying to replace the camera on my ipad air and i cannot find one that is reasonably priced. I have found that the ipad air and the ipad mini's camera look exactly the same and have the same specs. should i try to buy one? what is the model number the camera for the Ipad air so that i can compare to the ipad mini?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The original iPad Mini and the iPad Mini Retina use different cameras. The iPad Air and the iPad Mini Retina share the same rear camera - part number 821-1521-A. The original iPad Mini uses a different rear camera - part number 821-1521-06. I'm not sure what you consider to be a reasonable price, but you can find the correct part here.
Update
If you check this image, it appears that the bracket on the camera is different. But upon closer inspection, I think that the bracket pictured is only held in place with adhesive. Good catch! Thanks!
这个答案有帮助吗?
得分 1
1条评论:
Thank you for you post and the link! but i have a correction for you. according to the link provided the camera is for the Air, mini, and mini/retina. but your did answer my question and i thank you very much!!!
完成的
添加一条评论
添加你的答案
Hitordie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 346
