跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
iPhone keeps dropping USB connection
My iPhone 3GS keeps getting disconnected from the USB port of my Mac Mini. I have tried restarting the phone and the mini as well as various other tricks found on Google.
When the phone is connected to the USB port, it gives the "charging" beep and sometimes it immediately disconnects while at other times it loses the connection after a minute or two. I have tried changing ports, using a different cable and connecting it to my PC, everything yielded the same fruitless result :(
Could anyone help with this please?
Thanks
IMZ
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
If what "markus weiher" said doesn't work you nedd to buy this part:
http://cgi.ebay.co.uk/iPhone-3GS-3G-S-Ch...
这个答案有帮助吗?
得分 1
添加一条评论
check the dock connector of the phone -- sometimes there is a lint inside - but there could be some fluid damage to the connector - in both cases i would clean it with a soft paintbrush - but when fluid was involved - i would use rubbing alcohol and the paintbrush
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
im 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,614
