跳转到主内容
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
won't power on unless unplugged then plugged in
washer will not power on unless you unplug from wall power outlet and let set about 5 min then plug back in to power and will start then
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Try the following---when the washer will not "wake-up"...
1) Press the START button at each corner (north/south/east/west). If the washer CONTROL PANEL "wakes-up" reliably at any position---check the START button. Does it look crooked/out-of-position compared to the POWER button?
If so---replace the CONTROL PANEL COVER.
2) If the START button looks normal---replace the DISPLAY BOARD.
3) Tap/bang on the washer at the top/left/rear corner (without damaging the sheetmetal or paint finish).
If the CONTROL PANEL "wakes-up"---replace the MAIN BOARD (sticking Power Relay).
Please let us know your results.
这个答案有帮助吗?
得分 3
1条评论:
banging did it - sticky relay!!!!!!!!!!! Thank you
完成的
添加一条评论
添加你的答案
mydogspaz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 31
总计 12,858
