跳转到主内容
Model A1320 / 8 or 16 GB capacity
156 个问题 查看全部
My mom wash my iPod then dry ina dryer by accident
hi my i pod don't work anymore my mom wash because i left my i pod on my shorts then she dry in a dryer after she takes the cloth out of a dryer she fund my i pod and the i pod don't turn on an apple don't cover the i pod with the warranty on water damage you know what can i change o how to repair? thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
The only way is to disassemble the iPod.
then you need rubbing alcohol and a soft paintbrush, then clean the logicboard and the dock connector - but be careful - the parts are tiny. if everything is clean, let it dry and reassemble it.
try charge it with the wall charger - maybe you'r lucky and it will work again
这个答案有帮助吗?
得分 2
1条评论:
Make sure you leave it powered off for a few days before you plug it in, though.
完成的
添加一条评论
Good! Now you can get a life! :-)
这个答案有帮助吗?
得分 -1
1条评论:
That's not a helpful answer... If someone else were to come along and look at this question, they would not find much of a solution in your answer.
完成的
添加一条评论
添加你的答案
luciano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,378
