跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
What to use for shim iPod home button?
The home button contact needs a shim I see some guys use bonding. What should I use? I see that JB weld stuff is that any good....? Also I'm not in the mood to make some investment in this stuff. As we know only a drop is needed.... So what have you used for this process of fixing the home button.?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I have used a couple of drops of super glue in the past. It's just important that you let it dry before adding more, and before reassembly!
这个答案有帮助吗?
得分 1
2条评论:
On all of the videos and step by step web pages on repairing the ipod touch 4g, I have yet to see what this shim looks like. Does anyone have a photograph? Apparently the shim is missing in mine. I took it apart to replace the screen and now the home button won't work.
完成的
@grybo1960 - There is not an "official" shim. The reason why a shim or spacer is necessary in some cases is that all replacement parts are not made to the exact same physical specs as the original parts. You can also use a small piece of Kapton tape as a spacer as well.
完成的
添加一条评论
添加你的答案
Chris Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 573
