跳转到主内容
Is it safe to use with the battery disconnected?
I just bought a new Late 2013 Retina MacBook Pro 13", and I want the battery to remain in top condition as long as it can. So I thought it would be a great idea to disconnect the battery to preserve it when I use it home for a couple days.
Any comments/advices?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Lets look at it this way:
  • If you dislodge the power cord, what you are working on will be corrupted so the battery is acting like a UPS protecting your work.
  • Your system was designed to be a sealed system
  • The space internally were the connector is located is not big enough for the connector to be disconnected without long term damage with the cover off or on.
  • Constant reconnecting will wear the connection and if you are not careful you could also damage your system if the unit was not fully off (sleep mode) when you altered things.
Bottom line here: leave it alone it was designed to be used this way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kiss Zsolt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 357
