Phone is ON, But screen no light
my phone delays to switch on and it also does not show anything on the screen it's in dark mode no back light
Hi,
If you have data backup try wipe data / factory reset.
But for back light maybe this is hardware problem - display or part of main board...
Regards.
这个答案有帮助吗?
It sounds like the back light for your phone may be broken. While it's not easy, replacing the screen/digitizer may solve your problem.
这个答案有帮助吗?
I had a phone where the phone was on, but the screen would not turn on. The Power Button has a little black button attached to the top of the cable that wraps over the top of the phone. It had fallen off the phone so the power button no longer made the screen come on.
I pulled the phone apart, and luckily the Little black button was in there loose still. I cut a piece of tape and stuck the black button on it before placing the tape over the cable, and putting it back into the phone. The phone screen powers on again when pressing the Power Button.
This may not be your issue by the description of your problem, but the title of your problem makes it sound like this could have been you issue.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 2,201
