跳转到主内容
加入维修社区 - 创建账户
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
Hard Drive replacement didn't worked...
Hi !
Due to a disk failure, I needed to get my hard drive replaced...
I'm contacting you because everything went good during the hard drive replacement but unfortunately when I tryied to reinstall the OSX system the HD wasn't found by the installation program...
The only thing I'm not sure of is the Hard Drive cable. Does it have to be plug in deeply or not ? Actually it doesn't seems to be pluged deeply. I got no problem disconnecting the ZIF cable by fliping up the ribbon cable of the old drive.
May I damaged the ZIF cable? Did I missed something like a power supply cable or is this the only cable related to the hard drive for the datas and power supply?
Thanks for you help and all the work you've done on this site !
Jérémie
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Did you format the drive before you installed it? If not that would be the problem. Follow this https://discussions.apple.com/message/15.... That should fix the problem.
Hope this helps,
John H. Laney
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Milmandre 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 147
