跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
Broken front glass. What do I need to fix it?
Accidentally broke my iPhone 4s (white / Verizon) last night. Only the glass got a single crack in it. The LCD still works perfect. The touch functionality still works perfect.
Do I just need something like this to fix it?
http://www.tmart.com/Glass-Lens-Screen-w...
I look at other solutions and they seem MUCH more expensive:
http://www.amazon.com/iPhone-Verizon-Spr...
iPhone 4S Screen
Is that because those other solutions are replacing more than just the glass? Like they are maybe replacing the LCD screen and/or the touch functionality as well?
iPhone 4S Screen图片
产品
iPhone 4S Screen
$34.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
I would not recommend changing only the lens. Get the entire assembly. The LCD and Lens are fused together. This makes it very difficult to remove the lcd without damaging it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jakobud 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 222
