跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
Won't agitate or spin?
This is only a couple of years old LHW0050pq front load compact machine. No heavy use-only one or two loads per week. There is no agitation or spinning but it does go through the cycles. I can hear the door lock click. The drain pump is working. When I first turn the machine on the pump comes on and pumps out water but it sounds like it is timing out (?) because I can hear the pump working for a long time. Then the machine fills with water and just sits there until the next step in the cycle (rinse). Again there is no agitation, but when it comes to the spin cycle it drains and then just sits forever on the spin. The lights never indicate that the cycle is complete. I have to turn off the machine and wait the 2 minutes to be able to open the door. I've tried unplugging the machine, etc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Brenda, does the agitator turn at any time?
完成的
添加一条评论
2个答案
No, not at all
这个答案有帮助吗?
得分 0
添加一条评论
I am having the same problem, does anyone have a solution.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brenda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 372
