跳转到主内容
所有制造商和服务提供商的手机的维修指南和拆解信息,包括苹果 iPhone 和三星 Galaxy 系列。 获取您亲手维修手机所需的一切资料。
73638 个问题 查看全部
Looking for a Universal LCD and Digitizer tester
Hey.
Im looking for a universal LCD and Digitizer tester. I can not find it anywhere.
Can it be right that i need to buy each and every phone on the marked to test LCD and Digitizers after repair? Is there not a machine out there somewhere where you can change cables on, so you can test more then one phone?
I found testers for iPhone 4 and 5, but im looking for a machine that can test all phones.
If not possible, then maybe one that can test all Samsungs, and one that can test all Apple phones, and one for HTC and so on..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hi Henrik,
Found you the solution?
I have similar problem.
Thanks, Regards.
完成的
I was looking for the same thing and kept running into the same problem. Yes there are a ton of the individual specific testers, but universal testers can be found.
https://www.alibaba.com/product-detail/M...
Make sure you do your research and use patience when searching for equipment. I have found that doing so not only ensures the quality of the equipment much better, but can save you thousands of dollars.
完成的
The best thing wich could be on the market , its not there yet ,is a universal external lcd, one socket , and several lose sockets to bring a dead phone with broken lcd to life
what if you got expensive phone , LCD is broken, but you cannot get into your important or personal data
I think a solution, like you plug an external monitor to your laptop, when laptop screen is broken, just like hat for phones or tablets
I think i might start a crowdfunding for this , only thing needs to be developed is a monitor with socket , and for every phone on the market is already test cable available
完成的
添加一条评论
2个答案
已选择的解决方案
Sorry Henrik no such tool.
You see each manufacture of LCD and the OEM they sell it to have their own signaling & connection system.
Even the Apple tester you have now will likely not work in a newer version of iPhone as Apple is also not fixated on having a universal tool even for their phones.
Apple is more rigid than the others, just look at Samsung with all of the different models they offer, many different LCD systems!
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your answer. I was hoping that there was obe out tere somewhere, but i didnt count on it. I was thinking like u wrote, that the systems are different and i have to buy all the phones for testing the screens.
完成的
添加一条评论
other options are cheaper blacklisted phones with broken glass
or demo phones / motherboards.
But it would be nice to have a universal tester…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Henrik 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 4,431
