跳转到主内容
一部诺基亚品牌的Windows phone,2013年4月发布。
82 个问题 查看全部
How can I fix my broken power button?
Recently my power button had stuffed up and everytime i use it i have to take the case out and use my fingernails to press it as hard as i can to turn it on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
5条评论
I have the same problem
完成的
Omg its works I can't believe this thanks sooooo very much
完成的
I
have had this problem for a while
完成的
Thank you! This totally worked.
完成的
This worked. Thanks so much
完成的
添加一条评论
10个答案
最有帮助的答案
Step by step video guide. Fixed in one minute with scissors and a pill blister pack. http://m.youtube.com/watch?v=rLpmEPqE668
这个答案有帮助吗?
得分 3
1条评论:
I hope you get this but it works thanks to u!!! Omg
完成的
添加一条评论
Try This go to http://www.youtube.com/watch?v=BLRlFMVYt...
这个答案有帮助吗?
得分 1
添加一条评论
I confirm Etain's solution: the pill blister trick works perfectly for power & volume buttons. You can try without opening the phone but the best way is to open it (only 8 screws!), so you can position precisely the pill-blister and even secure it to the case using a bit of adhesive tape. My Lumia 520 works like a champ since I fixed it this way months ago. Go to youtube for tutorials!
这个答案有帮助吗?
得分 1
添加一条评论
Well everything goes bad eventually, anyway get a junk phone just like yours and steal the keypad off of it. The spring is broke under the button and or is misaligned (which you could take off and put in another,but very hard to do w/o losing all the parts to the other buttons) And then being very very careful when swapping out ,cause the mini parts are crazy small.
这个答案有帮助吗?
得分 0
添加一条评论
Hello,
Manually repairing the Lumia power button may void your warranty. I'd recommend you to take it to the nearest Nokia Care shop and ask them to repair it for you. Most probably, they won't charge you any money as its still in warranty period.
Hope it may helps you!!
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem with the power button. It somehow broke off and I am not able to power off the phone causing my battery to drain very quickly. It doesn't pay to have this fixed because the cost of repair is almost the same price as a new phone. The phone still works but who wants a phone that is in constant charge mode! These Lumias are inexpensive enough to buy a new one, that is if you like the phone enough, and I do.
这个答案有帮助吗?
得分 0
添加一条评论
take the battery out of the phone that will turn the phone off for you.
这个答案有帮助吗?
得分 0
1条评论:
添加一条评论
My power button is broken I hold
Its not on
And my windows phone app is gonee
这个答案有帮助吗?
得分 0
添加一条评论
my power button is broken any ideas how to fix it? its been broken for awhile now and i cant use it at all. the only way i can turn it on is by the camera or by my charger.
这个答案有帮助吗?
得分 0
添加一条评论
I understand....had the same problem... Bro use the app touch lock..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vy Bee 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 26
总计 16,679
