跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
screen is blank after replacing battery
Hello,
Replaced an old battery with a brand new one. Same voltage and current. With the new battery, the screen is blank. I can log on, play music, talk to the Voice Control, access the harddrive via iTunes, ..., just a blank screen. Any idea? I'll attach a picture.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Hi, have you tried pressing the home and power button together for about 10 secs and then pressing the power button to power it up again? If that still does not work, check if the cable is seated properly. Still no luck, then u might have damaged the flex cable when u installed the screen. Write back on what u did. Good luck.
这个答案有帮助吗?
得分 0
1条评论:
Yes, thank you. Long story short: this 3GS I gave to my 9 yo son when I upgraded to the 4G last year; he uses it as a sort of "ipod Touch." Anyway, earlier last year, he accidentally spilled water on the phone, which shorted out the power button (or at least made it inop) so I couldn't do as you suggested. However, we were able to reboot the phone via computer. Had to restore it to an earlier saved setting, but it works fine now. Guess I just had to power down the phone, which I was unable to do - normally. Thanks again for the suggestion, hope this helps someone in a similar situation!. Adam
完成的
添加一条评论
添加你的答案
atkach 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 63
