跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Cannot get past opening screen
This iphone 3g will not take a charge or go beyond the opening screen when I turn it on. If I unplug the charger it goes dead. It will not update even though itunes finds it. What could cause this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
You probably need a new battery. You can order one here and then use this replacement guide. Be sure that you have the proper tools - if there are any that you don't have, you can order the battery replacement kit for a few dollars more.
Replace a 1150 mAh battery compatible with iPhone 3G and fix problems with charging and battery life.图片
产品
iPhone 3G Battery
$14.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robin Harvey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 52
