跳转到主内容
型号A1288,闪存容量:8、16及32GB
The screen doesnt work
The screen of my iPod doesn't work, i try to turn it off, or turn it on and it dowsn't work when i connect the iPod to the pc, the pc recognize the iPod touch but the screen is still black, i can't listen to music the last time it worked normally i was listening to music and then it suddenly stopped when i tried to see what was happening the iPod screen was black... :( i don't think it turned off because of the battery, when i was listening to musci i remember that the battery was in 50%
sorry for my english :(
help please i'm desesperated because i'm in bolivia and there's nnowhere i can go to get the iPod fixed, i bought it in france 6 months ago...
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
The iPod charge when i connect it to the computer... i tried to reset the iPod and it doesn't work...
完成的
does in itunes everything look normal ?
完成的
yes in itunes looks normal
完成的
did you try to make a screenshot ?
(press and hold the power button and then press the home button - this should work with firmware 2.x to 3.x - you should hear a shutter noise and after that, connect it to the computer and look inside the dcim folder of the iPod)
完成的
添加一条评论
1个答案
最有帮助的答案
does itunes report any problem or will it connect normal ?
does the iPod charge when you connect it to a computer ?
maybe you should backup your stuff and try to make a hard reset (press and hold the Sleep/Wake button and the Home button for at least 10 seconds - then the iPod reboots) if that won't help - restore it with itunes.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,311
