跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Replace HDD with SSD and Superdrive with HDD
Hi –
I have seen plenty of guides for replacing the HDD in a 24inch, early 2008 iMac with an SSD but I'm looking to put that spare HDD in the Superdrive slot too. My Superdrive is currently not working so it makes sense to have an SSD as a startup disk and utilise the old HDD as a scratch disk or drive for files. Does anyone know what I'd need to be able to do this and whether it's actually possible with the existing connectors?
Many thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You need an Optibay kit… Otherworld Computing would be my go to source.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
2条评论:
Thanks machead3. I just took a look at the Optibay kit but it doesn't say that it comes with a PATA to SATA connector, although I'm sure it must?
完成的
I don't know... talk to OWC about it. They can set you up with what you need.
完成的
添加一条评论
添加你的答案
Gordie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 796
