跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
Install SSD, 3 answer
Hi all, thank you first for reading and maybe replying my answer (wtf my english, sorry).
I know i could search on the web, but on it i couldn't find all I needed. I'm here because I need to replace my HDD with an SSD. I didn't understand 3 thing:
1) I have a SATA 2 on my iMac and the SSD is SATA 3. Ofc I'll lose performance, so... Can I do something to resolve that? (Change my iMac SATA maybe?)
2) My iMac will not be filled up, so I can put my SSD as first and only HD. Is that ok? Can I do that? (Or it's better to put it together my default HHD [it's called fusion drive right?])
3) I read that to put my SSD I need at all cost to remove my SuperDrive (CD and DVD drive) and then but a support, is that right?
I know, a lot of answer, but I say thank you a lot if u can reply completely.
Ty for your time and patience again.
BB - Alberto
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You can not change the SATA speed on your machine - it's a function of the bus. Some sATA III drives play quite well at lower speed (they are "self-limiting" and virtually transparent to the user) others have to be manually set to lower speed (do some research - see links below).
As for your proposal see this and this previous answers to the same question.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
albertobagnacani 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 476
