跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Phone not turning on after reassembly.
My iPhone's camera went black and the flash stopped working. So, I thought the connection must have gotten lose. I disassembled the phone up to the step of "disconnecting the battery connection cable". I tried to remove the battery, but gave up due to the fear of damaging it. Then, I put the phone back together. I didn't turn on! I tried every method and also connected it to iTunes to test in DFU mode, but unfortunately, it didn't respond. Its 13 months old right now. Please help me revive it!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Make sure the battery is properly connected. You might have damaged the battery connector.
这个答案有帮助吗?
得分 0
2条评论:
I don't think I damaged the connector because I took special care opening it. Also made sure that it was properly connected before closing the phone.
完成的
Either the connector is damaged or something else on the board was damaged. Can you post a picture of the battery connector?
完成的
添加一条评论
I had this try the hard reset as well, power and home
这个答案有帮助吗?
得分 0
1条评论:
Did that many times already.
完成的
添加一条评论
添加你的答案
Mohit Anchalia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 515
