跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
Upgrading Graphics Card by Replacing Logic Board.
I'm fully aware of the fact that the graphics card for a Macbook is soldered into the logic board and as such can not be replaced by itself. However, I've read online that it is possible to update the card by replacing the logic board itself.
Is this actually possible, and assuming that this is possible, will I be able to use a logic board from a later generation, or will I have to stick to one from my MacBooks generation (late 2009)?
Finally, if this is possible, is it even a good idea?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Generally you have to stay within the same model year because from year to year the frame/case construction changes. If you have a late 2009 model the 09 to mid '10 boards fit.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Coby Stump 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 835
