跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
rear camera is black
Happy new year.
I have changed the charging port and home button to an iphone 4s and rear camera after testing is not working!!!!
It is completely black although it shows the choises on the bottom (video camera etc) and you could swap to the front camera which is working. The shutter on the rear camera is not anywhere and that makes me worry. I have done restore and hard reset but still nothing. Do you thing if I will change the camera it will work? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Take a look around the camera connector and make sure you didn't damage any of the filters, resistors or capacitors if you find any missing try to jump them.
这个答案有帮助吗?
得分 0
添加一条评论
Make sure there isnt an issue with the little gold grounding finger, and that the plug is seated correctly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
giannins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 148
