跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
New screen / glass, touch not working 100%.
Good Day All,
I had ordered a new front glass replacement which came with the LCD and digitizer etc, I got this on my phone without any issues, the screen works 100%, however, the touch screen doesn't appear to be functioning 100%.
I opened the notes app and tried typing each letter of the alphabet, I had difficulty tapping on "H" and "N" and could not hit at all "J" and "U". If you look at the keyboard these keys are all in the same vicinity from top to bottom on the screen. I am wondering if I maybe didn't put down the cable all the way on the motherboard? Or if I got a bad screen?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Either is a possibility. Easy enough to simply make sure the digitizer cable, closest to camera of the two screen flex connectors, is perfectly in place. If the digitizer is faulty, then when you replace the screen again with a new one, be very careful with the digitizer flex, as it is very vulnerable to damage during installation.
这个答案有帮助吗?
得分 1
添加一条评论
buy original screens for replacement, there is a lot of crap screens floating around out there. here is a info graphic on how to tell the difference.
http://www.syncedrepairs.co.nz/blog/orig...
fixit sell good quality. avoid eBay.
这个答案有帮助吗?
得分 1
添加一条评论
Phone screen crack
You can send me trick
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darren Peck 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 124
