跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
SSD not recognized in system
Well I have the same problem, I bought a Kingston HyperX SSD SATA 3. I replaced the Apple HDD (Toshiba) and the SSD isn't recognized, even in disk utility. I also tried with a Hitachi HDD it also is not recognized, the only HDD recognized is the Apple Toshiba drive.
I have a MBP mid 2012
Any idea?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Well, I changed the sata cable and it works now :)
这个答案有帮助吗?
得分 2
2条评论:
what type of cable did you change it to?/
完成的
It depends, you need to search the data cable for your specific macbook
完成的
添加一条评论
See this similar problem. It could also be an EFI/driver problem. Have you checked the manufacturers support site/knowledge base?
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
Chinese:
我觉得你的 Kingston HyperX ssd sata3 有问题,去更换一个试试吧
English:
I think you have a problem, Kingston HyperX ssd sata3, try to replace with another.
这个答案有帮助吗?
得分 -1
1条评论:
:), the problem was the data cable...
完成的
添加一条评论
添加你的答案
Cristian Kodiac 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 996
