跳转到主内容
Repair manuals and information for the Microsoft Surface line of tablets.
128 个问题 查看全部
Is it possible to upgrade the surface processor?
Hi I was looking at the specs of the Microsoft surface rt and the surface pro and the only really noticeable differences are the Operating System (8.1 rt vs 8.1 pro) and the processor (Nvidia Tegra 3 quad core vs intel i5 dual core). Is it possible to put a intel i5 processor into the surface rt allowing it to then download applications off the internet?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
已选择的解决方案
From the IFIXIT teardown: Surface logic bd we can see all of the chips are soldered so the answer is no.
这个答案有帮助吗?
得分 5
添加一条评论
Well, you would need to remove the old processor which means taking apart you RT and buying a new Intel processor that will fit.
But, it might not work, in the process you could break your computer. So get an expert to help, or someone who is good at taking apart and putting back together pc's.
Hope this helps. I'm testing it out myself.
这个答案有帮助吗?
得分 1
1条评论:
Sounds like mouth diarrhea in a puddle of hot air !!! @ work here.
完成的
添加一条评论
So, this will work if you have the time and steadiness of hands. I have a Surface RT and I upgraded the processor to an intel i7 but I had to very carefully remove the NVIDIA tegra and solder the i7 in contact by contact. It was totally worth it in the end, but it is very experimental, so I wouldn't recommend it for the daily noob, regards, EJS
这个答案有帮助吗?
得分 0
4条评论:
Ethan how do you choose the processor in a surface pro 4 ? Did you put a 16gig ram also and replaced the ssd ?
完成的
This is complete bullshit and shows an utter lack of knowledge on this subject.
完成的
Would this work on a surface pro 5 potentially and could you upgrade the ram aswell and where did you aquire the cpu?
完成的
This is not true. No other information... cpu have different socket, different architecture, different pin configuration. You can replace the nvidia tegra, just with another nvidia tegra
完成的
添加一条评论
Best senerio is to sell your RT and go buy a laptop, shop dreaming
这个答案有帮助吗?
得分 0
添加一条评论
I think the answer that best sums it up is as follows:
  1. keep your days job
  2. do your day job well
  3. after expenses, save up to the tune of the next surface pro with an CPU upgrade
  4. shop around for the new upgraded surface pro
  5. buy it
  6. Sell the old one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Lozinski 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 92
总计 20,717
